MACsec.MKA.AllocSecYDrvrFail
Description
Could not allocate memory for Secure Entity (SecY) driver object, which is required for MACsec.
Remedy
This is an unexpected internal condition needing technical assistance. Check if sufficient memory is available and memory is not occupied by other processes: "show memory" "show memory process macsec" If the problem persists, contact technical support with the following information: "show tech-support"
Severity
Critical
Message Text
Failed to create SecY driver object on port %slotPort%
Message Parameters
Name Type
slotPort SlotPort
Applicable Platforms
